Here is my JIRA API curl configuration
JIRA_USERNAME=
JIRA_API_TOKEN=""
JIRA_BASE_URL
curl -u "$JIRA_USERNAME:$JIRA_API_TOKEN" \
-X POST \
-H 'Content-Type: application/json' \
$JIRA_BASE_URL/rest/api/3/issue/ \
-d '{
"fields":{
"project":{ "key":"SR" },
"issuetype":{ "id":"10935" },
"summary":"Issue Created by Bash JIRA API Call",
"description":"Issue Created by Bash JIRA API Call"
{"errorMessages":["You do not have permission to create issues in this project."],"errors":{}}[root@rmslab2 working
This is not an answer but reiterating what others have reported already. And yes, I have checked multiple times what I am doing and this does not square up.
I am having exactly the same problem as described above. I have create a Personal Access Token for the very account I am able to create issue types in JIRA through the browser.
This simple command should work:
curl -v -D- -H "Authorization: <pat removed for obvious reasons>" \
-H "Content-Type: application/json" \
--request POST \
--data '{"fields": {"project": { "key": "CIP"},"summary": "curl","description": "curl script","issuetype" : {"name": "Task"}}}' https://<company_name>.atlassian.net/rest/api/3/issue
But it does not with the error:
Some AI LLM tool suggested this:
Verify PAT Permissions:
Go to your Atlassian account settings
Navigate to Security > Personal access tokens
Check that your token has the necessary permissions (read:jira-work, write:jira-work)
Consider creating a new token with explicit permissions for issue creation
But I do not see those options on my JIRA installation. I can only create tokens with an expiry date. Nothing else.
This is the JIRA I am using:
Build Number: 100283
Build Date: 2025-04-10T17:15:24.000+0200
Deployment Type: Cloud
If you still think we are doing something wrong, can you suggest some different way of debugging this that is different than what I have tried already?
Thank you!
Welcome to the Community!
It definitely seems like a permission problem. The error message says that your user does not have the necessary permissions to create an issue in that project. Probably the Outlook Plugin was integrated with a user who has the necessary permissions but your REST user might not have them.
Please ensure that the user account specified by $JIRA_USERNAME
has the necessary permissions to create issues in the "SR" project.
