Unable to migrate Jira cloud project between two Jira organizations.
Usha B S February 13, 2023
We are trying to migrate project between two organizations. We have an Org Admin permission on both the sites as well. Users are migrated but getting below error for Project migration.
"2023-02-14T05:10:54.694639Z,5ec79e4f-efcd-34a3-a11f-27192b046ab9,Migration of Project failed. Reason: [ Workflow with id AIDT Sub-task Workflow ] has missing dependencies on {[ Resolution with id .. ]}. This caused 0 other items to fail. This can happen if these dependencies aren’t present in the export file or aren’t supported by the migration tool"
 We can see the same resolution ID in both the organizations. If anyone has any insight or advice as to how I can accomplish this I would be extremely grateful! Thank you in advance for the help!
James Seabrook February 15, 2023
We are trying to do the same thing.
If you haven't already I would raise a ticket with Atlassian Support. They should be able to give some insight as they have access to the innards of the data structure. They've already helped me with a previous problem with a migration. But it's a tricky business.
FREE
