Unable to transition issue after adding "Comment" field as validator for a transition
Aditya Mulukutla June 13, 2024
I added the "Comment" field as required using validator for a transition in a particular workflow in one of my JIRA Company managed software projects.
When I try to transition an issue, I get the "Transition Failed" error notification even after adding a comment to the particular issue.
I am guessing I have to figure out a way to add text to comment field while transitioning the issue. How do I accomplish this? Am I moving in the right direction?
Thanks!
2 accepted
4 votes
Sam Spencer
June 13, 2024
When editing the workflow click on the transition and click edit
Then on the next pop-up in the 'screen' drop down choose comment screen
Do this will make the comment screen appear during the transition
Sam Spencer
June 13, 2024
Not sure if it will work buy try - 'Add Transition Screen' and add the Comment screen.
This will make it pop up while transition is taking place
I am fairly new to JIRA. How do I create a screen which will prompt me to add comments? Thank you!
This worked. I created a transition screen and added it to my transition. :)
Like Sam Spencer likes this
Sam Spencer
June 13, 2024
See my reply above - forgot to put it in the reply section
Thank you Sam. This worked like a charm.
