We are integrating Jira Cloud via the REST API to sync issues between two Jira instances. While updating the description of an issue (to include text + attachment reference using mediaInline
), the API call consistently returns 400 Bad Request
Unfortunately, since you haven't provided any information such as:
...then there's probably little insight anyone can offer as to what the problem might be.
PS. Given that you duplicated this question over in the Developer's Forum, the only advice I can give is the same as over there... refer to the How to Ask A Good Question thread to remind yourself again of the minimum standard that you, as a programmer, would expected of another programmer if they asked you to give them assistance with that problem.
