Attempting a fresh install of MySQL 5.1.73 and JIRA 7.3. Both are running on their own instance of Redhat Linux 6.7
I have installed and setup MySQL and JIRA as per the JIRA guide, placing the mysql-connector-java-5.1.41-bin.jar in atlassian/jira/lib
My my.cnf looks like below:
[mysqld] datadir=/var/lib/mysql socket=/var/lib/mysql/mysql.sock user=mysql # Disabling symbolic-links is recommended to prevent assorted security risks symbolic-links=0 default-storage-engine=InnoDB max_allowed_packet=256M innodb_log_file_size=256M [mysqld_safe] log-error=/var/log/mysqld.log pid-file=/var/run/mysqld/mysqld.pid
And the JIRA error I get when going through setup is (JIRA forums failed to let me upload an image):
Error connecting to database
Unknown system variable 'default_storage_engine'
I've tried replacing the - with _ but it made no difference. I don't have a dbconfig.xml yet as I haven't managed to get through the JIRA setup.
My mysql.properties file contains the following line:
databaseUrl=jdbc:mysql://localhost/jira?autoReconnect=true&characterEncoding=utf8&useUnicode=true&sessionVariables=storage_engine=InnoDB
which I've tried removing the storage_engine variable from the URL and also renaming to default_storage_engine but this both changes made no difference.
The catalina.out log file has this as the last error:
2017-03-31 05:32:26,408 http-nio-8080-exec-8 ERROR anonymous 332x6x1 6ho9xv xx.xx.xx.xxx/secure/SetupDatabase!connectionCheck.jspa [c.a.config.bootstrap.DefaultAtlassianBootst$ java.sql.SQLException: Unknown system variable 'default_storage_engine' at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:964) at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3973) at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3909) at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:2527) at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2680) at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2497) at com.mysql.jdbc.StatementImpl.executeUpdateInternal(StatementImpl.java:1540) at com.mysql.jdbc.StatementImpl.executeLargeUpdate(StatementImpl.java:2595) at com.mysql.jdbc.StatementImpl.executeUpdate(StatementImpl.java:1468) at com.mysql.jdbc.ConnectionImpl.setSessionVariables(ConnectionImpl.java:4999) at com.mysql.jdbc.ConnectionImpl.initializePropsFromServer(ConnectionImpl.java:3212) at com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:2249) at com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2035) at com.mysql.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:790) at com.mysql.jdbc.JDBC4Connection.<init>(JDBC4Connection.java:47) ... 3 filtered at java.lang.reflect.Constructor.newInstance(Constructor.java:423) at com.mysql.jdbc.Util.handleNewInstance(Util.java:425) at com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:400) at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:330) at java.sql.DriverManager.getConnection(DriverManager.java:664) at java.sql.DriverManager.getConnection(DriverManager.java:247) at com.atlassian.config.bootstrap.DefaultAtlassianBootstrapManager.getTestDatabaseConnection(DefaultAtlassianBootstrapManager.java:347) at com.atlassian.jira.config.database.JdbcDatasource.getConnection(JdbcDatasource.java:211) at com.atlassian.jira.config.database.DatabaseConfig.testConnection(DatabaseConfig.java:87) at com.atlassian.jira.web.action.setup.SetupDatabase.testConnection(SetupDatabase.java:225) at com.atlassian.jira.web.action.setup.SetupDatabase.doValidation(SetupDatabase.java:189) at com.atlassian.jira.web.action.setup.SetupDatabase.doConnectionCheck(SetupDatabase.java:121) ... 3 filtered at java.lang.reflect.Method.invoke(Method.java:498) at webwork.util.InjectionUtils$DefaultInjectionImpl.invoke(InjectionUtils.java:70) at webwork.util.InjectionUtils.invoke(InjectionUtils.java:56) ... 2 filtered at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:63) ... 7 filtered at javax.servlet.http.HttpServlet.service(HttpServlet.java:729) ... 49 filtered at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:80) ... 1 filtered at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:78) ... 28 filtered at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30) ... 27 filtered at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25) ... 28 filtered at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) at java.lang.Thread.run(Thread.java:745)
Now I know there is an issue with MySQL 5.7 and JIRA 7 relating to this, but this is MySQL 5.1.73. There was another post on here a few weeks relating to the exact same issue but the trail went cold so thought I'd post a new post as this is blocking everything for me right now.
Any help greatly appreciated.
I gave up on this, must be some incompatibility between these versions.
For anyone else who stumbles across this issue, the way I got round it was to uninstall MySQL 5.1 and install MySQL 5.6 and everything worked as it was meant to.
I believe the problem stemmed from the default yum repository that ships with Redhat 6 Enterprise. I followed the steps at this link https://dev.mysql.com/doc/mysql-yum-repo-quick-guide/en/ to update the yum repository and then revert to defaulting to MySQL 5.6 (rather than the default which is MySQL 5.7). I installed everything as the rest of the link above instructs, and then continued to setup as per JIRA instructions and everything worked first time.
The name of the variable containing the "Default Storage Engine" changed between MySQL 5.5.3 and 5.7.5 .
Before 5.5.3, there was only "storage_engine". Starting with 5.5.3, one could use both "storage_engine" and "default_storage_engine". Beginning with 5.7.5, only "default_storage_engine" remained.
BTW: The release date of MySQL 5.5.3 was 2010-03-24, that of MySQL 5.7.5 was 2014-09-25.
it's work.
in MySQL 5.1 (default version on CentOS6.7) + jira 7.13.
modify dbconfig.xml
<url>jdbc:mysql://address=(protocol=tcp)(host=localhost)/jira?useUnicode=true&characterEncoding=UTF8&sessionVariables=storage_engine=InnoDB</url>
donot test in config.sh , just run start-jira.sh.
