Unzipped Jira stand-alone initial application start - plugins setup errors results in lock
Mike Jackson
October 30, 2011
Hi. Trying to wrap up my first Jira install. My problem is below. I'm wondering if it's a permissions issue? Thanks.
  • Linux Jira 4.4.3 standalone (tar.gz archive)
  • Unpacked via GNU as instructed
  • Dedicated jira-tomcat user for running Tomcat
  • $JIRA_USER=jira via bin/user.sh
  • jira-tomcat owns $JIRA_INSTALL
  • jira owns $JIRA_HOME, $JIRA_INSTALL/logs, $JIRA_INSTALL/logs, $JIRA_INSTALL/temp, $JIRA_INSTALL/work
  • Jira opens in locked mode
2011-10-31 04:04:15,466 main INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.admin, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.support.stp, com.atlassian.jira.rest, com.atlassian.crowd.embedded.admin, com.atlassian.gadgets.dashboard, com.atlassian.streams.actions, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams.core, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.gadgets.directory, crowd-rest-plugin, com.atlassian.sal.jira, com.atlassian.jira.gadgets, com.atlassian.gadgets.publisher, com.atlassian.jira.jira-project-config-plugin, com.atlassian.oauth.serviceprovider, crowd-rest-application-management, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.embedded, com.atlassian.jirafisheyeplugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.streams, com.atlassian.gadgets.oauth.serviceprovider], 32 seconds remaining
2011-10-31 04:04:10,432 Timer-0 WARN      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.crowd.embedded-crowd-admin-plugin, config=osgibundle:/META-INF/spring/*.xml)]
2011-10-31 04:04:26,013 Timer-0 ERROR      [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.crowd.embedded-crowd-admin-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.sal.api.auth.LoginUriProvider)] (from bean [&loginUriProvider]), Dependency on [(objectClass=com.atlassian.sal.api.websudo.WebSudoManager)] (from bean [&webSudoManager])
org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.crowd.embedded-crowd-admin-plugin' has timed out
        at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454)
        at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50)
        at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105)
        at java.util.TimerThread.mainLoop(Timer.java:534)
        at java.util.TimerThread.run(Timer.java:484)
2011-10-31 04:04:27,493 main INFO      [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.oauth.admin, com.atlassian.applinks.applinks-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.support.stp, com.atlassian.jira.rest, com.atlassian.crowd.embedded.admin, com.atlassian.gadgets.dashboard, com.atlassian.streams.actions, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.streams.core, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.gadgets.directory, crowd-rest-plugin, com.atlassian.sal.jira, com.atlassian.jira.gadgets, com.atlassian.gadgets.publisher, com.atlassian.jira.jira-project-config-plugin, com.atlassian.oauth.serviceprovider, crowd-rest-application-management, com.atlassian.gadgets.opensocial, com.atlassian.gadgets.embedded, com.atlassian.jirafisheyeplugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.streams, com.atlassian.gadgets.oauth.serviceprovider], 20 seconds remaining
2011-10-31 04:04:28,524 Timer-0 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&loginUriProvider' for plugin 'com.atlassian.crowd.embedded.admin' with filter (objectClass=com.atlassian.sal.api.auth.LoginUriProvider)
2011-10-31 04:04:28,524 Timer-0 ERROR      [plugin.osgi.factory.OsgiPlugin] Never resolved service '&webSudoManager' for plugin 'com.atlassian.crowd.embedded.admin' with filter (objectClass=com.atlassian.sal.api.websudo.WebSudoManager)
2011-10-31 04:04:28,524 Timer-0 ERROR      [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.crowd.embedded.admin
Mike Jackson
October 31, 2011
I wiped everything and tried the stand-alone installer. Wow...much easier. But same errors.
I'm running on an Amazon EC2 Micro instance. It's my understanding there is simply not enough horsepower on the micro, and I need a Small instance. Things start timing out (1 minute timeout IIRC) and just don't start properly.
Oh well...<3 Jira...but gonna have to look for a more light-weight solution. Thanks.
