Hi all,
I have to update the single issue picker (custom field name = Test Linking) based on the issue key (TEST-130) but no luck. I am getting the below error when logging.
def issueTest_130 = issueManager.getIssueObject("TEST-130")
def myval = cFieldValue
MutableIssue issueTest_130_= (MutableIssue) issueTest_130
def textCf2 = customFieldManager.getCustomFieldObjects(issueTest_130).find {it.name == "Test Linking"}
log.debug("textCf2 : "+textCf2)
log.debug("textCf2 : "+textCf2.getClass())
if (textCf2) {
def changeHolder = new DefaultIssueChangeHolder()
textCf2.updateValue(null, issueTest_130_, new ModifiedValue(issueTest_130_.getCustomFieldValue(textCf2), myval),changeHolder)
log.debug("testcf2 is updated")
Log:
2020-03-01 14:03:08,403 DEBUG [acme.CreateSubtask]: textCf2 : Test Linking 2020-03-01 14:03:08,404 DEBUG [acme.CreateSubtask]: textCf2 : class com.atlassian.jira.issue.fields.ImmutableCustomField 2020-03-01 14:03:08,408 ERROR [workflow.ScriptWorkflowFunction]: ************************************************************************************* 2020-03-01 14:03:08,408 ERROR [workflow.ScriptWorkflowFunction]: Script function failed on issue: TEST-133, actionId: 81, file: <inline script> java.lang.ClassCastException: java.lang.String cannot be cast to com.atlassian.jira.issue.Issue at com.codedpoetry.easylinks.customfields.SingleIssueLinkCF.updateValue(SingleIssueLinkCF.java:63) at com.atlassian.jira.issue.fields.ImmutableCustomField.updateValue(ImmutableCustomField.java:426) at com.atlassian.jira.issue.fields.ImmutableCustomField.updateValue(ImmutableCustomField.java:396) at com.atlassian.jira.issue.fields.OrderableField$updateValue.call(Unknown Source) at Script1172.run(Script1172.groovy:77)
Hello @Sibi_K / @Rolf Lader ,
Any luck on this issue?
