Hi.
My company still uses Jira 4.4.4 32bit and we want to upgrade to the new version (5.0.6 at this moment), but the 64bit edition.
I've found a tutorial explaining how to ugrade to v5. But, how can I upgrade from the 32bit setup to 64bit?
What files should I backup and move\replace in the new installation?
Is there any procedure to follow?
Thanks in advance.
Following can be done
Consider the following
Hi Carlos,
have a look here: https://answers.atlassian.com/questions/34717/how-easy-is-migrating-from-32bit-jira-to-64bit
Maybe you should first migrate to 64 bit and then upgrade to a new version.
Cheers
Thomas
How can I upgrade first to 64bit? The windows 64bit version was only released with the v5.
That answer only says to connect the 64bit edition to Jira database and then do the upgrade.
But, changing the Jira location does not require further steps, like moving atachments, indexing files, config files, etc?
Ins't there a guide for changing from 32bit to 64bit?
You didn't mention that you are using a windows 64 bit version...
So, why not upgrade first to Jira 5 (32 bit) and in another step migrate to 64 Bit as Nic suggested in the other question ?
But, what do I need to do when changing from 32bit to 64bit?
At this moment my Jira installation is at: "C:\Program Files (x86)\Atlassian".
If I install the 64bit edition It will be installed at: ""C:\Program Files\Atlassian".
I just need to know what should I backup and move from one folder to another.
And how can I install the 64bit? Should I install it with the 32bit or should I uninstall the 32bit first and them install the 64bit?
Thanks Thomas.
I think it's the same procedure as described here: https://confluence.atlassian.com/display/JIRA050/Migrating+JIRA+to+Another+Server
You have to do a new installation with 64 Bit and point it to the old Jira Home directory and Database. But don't forget to try the upgrade first in a test environment !!
