Upgrade Jira 8.0.2 to Jira 8.7.1
Oleg Lunkov
February 16, 2020
Hello. I can not upgrade Jira 8.0.2 (SEN-13502134) to Jira 8.7.1. I get massage "Your current database version won't be supported. " What should I do?
Daniel Ebers
February 17, 2020
Hi Oleg,
it's hard to say while we do not know any details about your infrastructure - but the error message suggests some relation to the database.
Which database type and which version is currently installed on your server?
Daniel
Oleg Lunkov
February 19, 2020
Hi Daniel,
thank you for your answer. Some base information below.
Tipeh2
JNDI adress DBh2 jdbc:h2:file:/var/atlassian/application-data/jira/database/h2db
URL DBjdbc:h2:file:/var/atlassian/application-data/jira/database/h2db
Version DB1.4.185 (2015-01-16)
Driver DBH2 JDBC Driver 1.4.185 (2015-01-16)
What information is needed additionally?
Daniel Ebers
February 25, 2020
From what I can see your instance is running on the integrated H2 database. I am not sure if upgrades using that database are possible without any friction.
From documentation it is advisable to switch to a supported database (f.e. PostgreSQL in a supported version).
Daniel
