×I have upgraded my JIRA system from 6.1.6 to 6.3.15.
When I try to start JIRA, I get the following error:
SEVERE: Servlet.service() for servlet [action] in context with path [] threw exception [java.lang.StackOverflowError] with root cause
I am not getting a path for the error. I am running under Windows with Java 7.
I fixed this issue which turned out to be a memory problem.
I changed the allocation of memory to the windows service and it is working now.
Hi Liesa,
Do you get any more information about the problem in the atlassian-jira.log file in the <jira-home-dir>/log directory?
Or in the catalina.out log file in the <jira-install-dir>/log directory?
Best regards,
Peter
