Hi All,
I need to upgrade from JIRA 4.1 to JIRA 6.3.
There appear to be several methods to achieve this.
My question is.. (please excuse me if it sounds simplistic!!)
Is it possible to import a JIRA 4.1 XML file directly into JIRA 6.3 to restore the database?
Many thanks in advance..
Mike
I had similar task to upgrade JIRA 4.0.2 to 6.3.14 (my JIRA is connected to a postgresql database)
Steps I use to upgrade are:
What is important is that all three JIRA installations are separate - both INSTALL and DATA directories are different between JIRA versions
Only one version is running each time!
Review logs for issues that are related to your setup
Stavros
Hi Elijah, As yet, we have not done this upgrade, but when I have i will let you know how it went!! Mike
Hi Mike, I am in the same predicament where I am to upgrade a system from 4.1 to 6.3. Was wondering if you can shed any light on resources you used and how the process went. Thank you.
Hi Again Jobin,
Just to confirm your initial note, can I put JIRA 6.3 down directly on top of JIRA 4.3?
Mike
Yes, 4.3 to 6.3 can be a straight upgrade. I would still test it first.
OK, I accept that, but whilst I am upgrading my DEV system, users will be using the LIVE system.
Is there a documented method of determining the Delta's between the two systems and then importing them to the updated system.
currently, my DEV clone is 1 Month Old.
Also, I will hope to keep an up-to-date DEV clone for testing and implementation, up to now, this has all be done directly on the LIVE system.
Mike
There is no easy way to find the delta. It is advised to clone the Prod before you test the upgrade.
It is better to do this in steps. Upgrade JIRA to 4.3.x first and then upgrade it to 6.3.x. You can find the appropriate upgrade guides in the JIRA documentation.
Make sure you read all the release notes to understand the changes between versions. There are quite a lot between 4.1 and 6.3!
