Upgrade path for JIRA
Ram April 24, 2013
Hi All,
Can anybody suggest the Upgrade path for JIRA 4.4 to 5.1.6.
Thanks in advance.
Ram...
Nic Brough -Adaptavist-
April 24, 2013
Create a new application server at 5.1.6 then point it at your 4.4 database.
For proper details, read https://confluence.atlassian.com/display/JIRA/Upgrading+JIRA
Ram April 24, 2013
Hi Nic,
Is that ok with this process as there is a major release of JIRA 5.0.?
Jobin Kuruvilla [Adaptavist]
April 24, 2013
You can directly upgrade, as suggested by Nic (by pointing to DB) or by using the upgrade option in the installer. I normally recommend the upgrade option (gives all modified details, copies memory config etc). Skipping v5.0 is just fine.
Ram April 24, 2013
Thanks Jobin...
