Upgrading Jira 4.4.4 32 bit to Jira 6 64 bit
Rob Horan
January 22, 2014
I would like to uprgade Jira to version 6, 64 bit, and do so on the same machine. Is it possible to upgrade the existing installation as opposed to installing Jira 6 and restoring data separately then uninstalling Jira 4?
Zul NS _Atlassian_
January 23, 2014
Yes, it is possible to upgrade from 32bit to 64bit by upgrading JIRA manually. You can upgrade JIRA directly from JIRA 4.4.x to JIRA 6.1.6, however in some cases it is advisable to upgrade to JIRA 5.x first before proceed for 6.1.6. We strongly recommend to upgrade on a Testing environment first.e
Feel free to raise a ticket to us at support.atlassian.comif you encounter any issue during upgrading JIRA.
Rob Horan
March 12, 2014
Thank you! That was very helpful.
