×I upgrade to Jira 8.22.6 and the health check shows MS SQL 2014 is not supported.
Most staff use Jira SAAS in the cloud now but we have a few users still using on prem but with no JIRA applications being used.
All projects seemed to be working and while I accept there is a risk I see no functional impact with Jira 8.22.6 connected to MS SQL 2014 and its only going to be for a short time until we migrate on prem JIRA completely to cloud.
What are the rist staying with this?
Appreciate any help
Hello @Chris Boyes ,
Welcome to the Atlassian Community!!
It is always recommended from Atlassian to have the database compatible with your Jira.
As you mentioned it will work 8.22.6 with MS SQL 2014 but some of operation might not work properly.
It is always recommended to have the supported version of database.
Mayur
I appreciate that but this is only a stop gap measure and Atlassian have said it should not stop you migrating from on prem into the cloud which we plan to do soon.
Only reason we went to 8.22.6 was due to the fact our version was a significant vulnerability and cybersecurity was pushing me to get this upgrade done asap
Understood, yeah but it won't stop to migrate the data, but it is recommended. Great you have confirmation from Atlassian.
