Uploading Scrum Project CSV to Jira
Michelle Pawlow
August 4, 2021
Is there an easy way to transfer scrum lists of current projects, epics, user stories, % completion, and other relevant data from CSV file to Jira? My scrum team has been tracking our progress through excel for a while now and hoping to gain insight into additional metrics using the Jira Software. It would be great if Jira could also retroactively display velocity, burndown rate, and etc. from our previous dataset. I'm hoping there is an easier way than just manually entering all past projects into the site!
Alex Koxaras -Relational-
Hi @Michelle Pawlow and welcome!
There is a detailed guide here https://support.atlassian.com/jira-cloud-administration/docs/import-data-from-a-csv-file/
This will help you create your CSV file and upload it on a new project with a scrum board. However, you might need to adjust certain things in your project, prior of uploading it.
Alex
FREE
