Hi , I am trying to import using CSV to a custom checkbox list
<col style="width: 48pt;" span="3" width="64"/>
ImpactInBusinessVelocity | ImpactInBusinessVelocity | ImpactInBusinessVelocity |
Velocity | Revenue Generating | NULL |
Velocity | Revenue Generating | Cost Saving |
Velocity | NULL | Cost Saving |
NULL | Revenue Generating | NULL |
NULL | NULL | NULL |
please tell me how to import to a custom field called Impact in business that i already created
when mapping using csv i failed ...i can see only one value or (one marked) in case i have more are checked
ImpactInBusinessVelocity | ImpactInBusinessVelocity | ImpactInBusinessVelocity | Velocity | Revenue Generating | NULL |
in issue i see only Revenue genarting and there is no Velocity
I downloaded the latest plugin and now it is working ..Thanks Nic
https://plugins.atlassian.com/plugin/details/32645?versionId=456211
Right. That is covered in the documentation, as usual. Read http://confluence.atlassian.com/display/JIRA/Importing+Data+From+CSV and pay close attention to the section "valid file format", which tells you how to import multiple values into a multi-select field.
please have a look on the csv format:
ImpactInBusiness,ImpactInBusiness,ImpactInBusiness,ImpactInBusiness
Velocity,Revenue Generating ,Cost Saving,Increase Quality
Velocity,NULL,Cost Saving,Increase Quality
NULL,Revenue Generating ,NULL,Increase Quality
NULL,NULL,NULL,Increase Quality
I am maping ImpactInbusiness to existing custom field then i choosed a custom field Impact In Business
again not all values are imported
Are you mapping the incoming data?
Can you try moving all the nulls to the end of each line?
I am mapping the incoming data, and I removed all the nulls; My CSV format
Summary,ImpactInBusiness,ImpactInBusiness,ImpactInBusiness,ImpactInBusiness,Description,IssueType
Test 01,Velocity,Revenue Generating,,Increase Quality,Test 01,Bug
Test 02,Velocity,,Cost Saving,Increase Quality,Test 02,Bug
Test 03,Velocity,Revenue Generating,Cost Saving,Increase Quality,Test 03,Bug
Test 04,,,,Increase Quality,Test 04,Bug
Test 05,,Revenue Generating,,Increase Quality,Test 05,Bug
Can you please try it ?
Can you make sure you are selecting the same Jira field for each of the impact fields in the CSV? It should be asking you about each column separately.
Yes I am sure just I also opened a ticket
https://support.atlassian.com/browse/JSP-88487
please check the steps I followed
That project is not public - we can't see stuff you raise in there.
I've just tried to run your file into a test system, it's working fine for me.
Following are the steps i made
NIC Can you please tell me your steps.. are you sure you have more than 1 checked?
take the test 03 Test 03,Velocity,Revenue Generating,Cost Saving,Increase Quality,Test 03,Bug
I can only see that Velocity is Marked ..
I guess it only marks the first value it find and ignors the rest for each line
I am really stuck!!
That still doesn't tell us whether you have mapped ImpactInBusiness many times? Just to make it entirely clear, could you rename the columns in the CSV as (say) ImpactInBusiness_1, ImpactInBusiness_2, ImpactInBusiness_3 and so on.
Also, I apologise, I was not entirely clear when I was talking about "mapping". There's two things to look at - first, you need to link ImpactInBusiness_1, ImpactInBusiness_2, ImpactInBusiness_3 and so on to the same Jira field, "Impact in Business". Second, can you check that you ticked the "map field" check box next to each one of the columns on the screen where you link them?
do you think because I changed the design layout here
https://answers.atlassian.com/questions/2762/multi-checkboxes-design
I tried to import to using new custom fiels instead of exitsing but same result
The screen layout is not important - the CSV imports data into fields, it's got nothing to do with how they are displayed.
still no change
1-I renamed the CSV columns
2-mapped them to existing field Impact In business
3-I checked Additionally map field value for each of the columns
4-CSV header row Additionally map field value
ImpactInBusiness1
(imported as existingCustomField) Value from importer Target value in JIRA
Velocity:
ImpactInBusiness2
Revenue Generating:
ImpactInBusiness3
Cost Saving:
ImpactInBusiness4
Increase Quality:
I'm sorry, that makes no sense what so ever. When importing into a custom field, you tell Jira which column in your CSV contains the data, and if it's a select field, you map the options (Check boxes are a form of select list by the way - the difference is in the way they are displayed, not the actual data structures). I can't make out what you're even doing here, let alone what you are trying to do.
Hi Nic thank for your comment ,
I am trying to import 3 columns to the 1 custome field
if you think you do have another way please share it with me
in the old database these checkboxes are stored in 3 columns
