Looking for recent information of use of the WBS Gantt Start/Finish dates in other areas of Jira?
Ideally, want to use these dates for the Story Cards on the Kanban board to reflect a true Start/Finish date. (Without having to do a lot of manual data entry).
Please follow the steps below to configure the card layout for your Kanban board.
On your Kanban board click on Board > Select Configure
I hope this helps to answer your question.
What version of Jira do you have? Mine is not bringing up Start Date for WBS Gantt.
The Version we are running is 8.20.11
The version I am running is 8.14.0.
You will need to verify the name of the Start and Finish date fields you are currently using.
Please follow the steps below.
Follow the aforementioned steps for Kanban board configurations
Note: Please ensure that you look for the name of the Start and Finish date fields that you have verified in your Gantt configuration.
I hope this helps to address your concerns.
