I recently created an API Token in Atlassian to hopefully use it to access projects based on permission rules but I could not find any settings in projects where I could set permission rules based on API Token? Where can I set this?
Maybe I have the wrong idea in general about how API Tokens work.
Is there any documentation on using API Tokens in Jira? I found documents on creating an API token but nothing on actually using it.
Any help would be appreciated. Thank you.
So if I'm getting this right,
The API Tokens are tied to an account, and not used as a separate user entity altogether?
You will mainly use your api token when working with the REST api, you have that documentation in the developer site:
Server: https://developer.atlassian.com/server/jira/platform/rest-apis/
Cloud: https://developer.atlassian.com/cloud/jira/platform/rest/v3/
As Roma already stated it will use the same permissions that you have within Jira. If you need to build a function or something then you create a new user account for the function and provide that account with increased/decreased permissions based on what you want to do.
Hi Jeremy,
Think about API Token as your personal second password.
If you login with your username/token the system will give exactly the same permissions as you login via password or using UI.
Regards, Roman
