Does Crowd support a SSO for applications installed inside and outside my network?
For example - my JIRA is open to the internet, but my Stash is internal only. Can they both authenticate with a single Crowd instance?
Thx!
This configuration is supported. We use Crowd for SSO to our JIRA install (open to the internet) and Confluence (internal only). Works fine.
Geert
Can I ask you a few more technical questions on this setup? If so, I'll contact you outside this thread.
