Using JIRA AGILE without JIRA?
Martin Klingauf
May 29, 2015
I am quite interested in using "JIRA AGILE" (f.e. 50 licenses). Does it mean that
I even have to buy "JIRA" with 50 licenses too?  I am quite confusing, it seems to me
that JIRA AGILE needs to be purchased with JIRA. JIRA AGILE is not a stand alone
product?
Thanks for your request!
Nic Brough -Adaptavist-
May 29, 2015
JIRA Agile is an addon for JIRA.  It can't run alone, it's using all of JIRA's data as well as the application as a container.
Rodrigo Rosa
May 29, 2015
Hello Martin!
JIRA Agile works as an add-on for JIRA, so it is necessary to have a JIRA license with the same amount of users than Agile.
Rodrigo Rosa
Paulo Hennig
May 29, 2015
Hello Martin,
In additional to the previous responses, JIRA Agile license must match the user count and type of the JIRA Server license it is being used with. For instance, a 25 User Commercial JIRA Server license will require a 25 User Commercial JIRA Agile license.
You can check more information here
Norbert Janssens
You're right - JIRA Agile does not work without JIRA!
