Am using Jira automation, to create some default issues, we used to create manually in each of our projects.
And i need to set the value of the parent (epic) in each issue created
i tried to follow the example given , but am not sure i had it right:
"fields": {
"parent": {{issue.key}}.,
"labels": [
"bugfix",
"blitz_test"
hi @Amel LAOUINI ,
It's not possible put some value of the epic in a new issue directically, you need add a previous step.
Example
After then
and the last step
