Using Jira cloud for risk management
Boluwatife Onafujabi May 9, 2018
We want to be able to track project risks and organizational risks as a whole on jira cloud. So i will like to find out how this can be achieved.
Please note that the user is a jira core user
Thank you.
Ajit Rajput
You can create "Risk" issue-type and build screen, workflow and field configuration schemes around it such that it would serve/meet your organizational requirement.
For calculating the criticality automatically (i.e. probability x impact), you may utilize ScriptRunner's scripted field OR keep it as dropdown with pre-defined criticalities for manual user-selection.
Alternatively, if you looking for more capabilities/features around risk-management in JIRA, you may also think of using the plugin given here - https://marketplace.atlassian.com/apps/1213146/risk-register?hosting=cloud&tab=overview
Hope this information helps.
okay thank you
Like Una Catley likes this
Gorka Puente _Appfire_
Hi @Boluwatife Onafujabi,
Disclaimer, I'm the vendor of the following app!
In Comala Agile Ranking, you can use the risk Matrix: Severity vs Probability. A perspective designed for risk management
Gorka
