Using Multi User Field, create that many subtasks with them as the assignee
Kathleen Jacobs
Is this possible through a plugin or script?
We created a Field using the Multi User, where they can include as many users as they want.
All of these people need a subtask created and assigned to them. Is there a way we can do this?
Bhushan Nagaraj
June 4, 2013
Hi kjacobs,
Govardhan has done this recently using the script runner plugin by Jamie Echlin. He has provided the solution here.
https://answers.atlassian.com/questions/175354/create-sub-tasks-based-multi-select-custom-field
Cheers
Bhushan
Kathleen Jacobs
:( Getting:
  • This question or answer has been deleted.
  • The URL has an error.
Kathleen Jacobs
I have script runner and in the Post Function, after the Multi User Field is filled out, I want to add the script. With Script Runner, do i have to have the file seperate, how can I add it directly somehow? All i see as an option is Script Post-Function.
I have the script he gave but changed line one to match my field name.
So it looks like:
cfStewards = customFieldManager.getCustomFieldObjectByName("Stewards")
Collection<User> users= (Collection) issue.getCustomFieldValue(cfStewards);
if(users != null)
for(i in 0..users.size()-1)
Object AssigneeValue = users.get(i).getName();
issueObject = issueFactory.getIssue()
issueObject.setProject(issue.getProject())
issueObject.setIssueTypeId("10")
issueObject.setParentId(issue.getId())
issueObject.setSummary(issue.getSummary())
issueObject.setAssigneeId(AssigneeValue)
subTask = issueManager.createIssue(authenticationContext.getUser(), issueObject)
subTaskManager.createSubTaskIssueLink(issue.getGenericValue(), subTask, authenticationContext.getUser())
i++
Bhushan Nagaraj
June 4, 2013
Hi kjacobs,
You can easily use the code and write your own post-function workflow plugin if you want.
Thank you
Bhushan
Bob Swift
June 4, 2013
