Using Next-Gen Project, How do I add simelanes to a board?
Justin Dyer
January 23, 2019
I am trying to add swimelanes to my next-gen project board and cannot figure out how to do this.
Aaron Williams
January 23, 2019
I just went ahead and created a test next-gen project, and it doesn't look like swim lanes are a feature in there at the moment. The closest I could get was using the "group by" option to create what looks like swim lanes based on Assignees, which does suggest that they could add more functionality soon.
I checked if adding labels or flags to the issues allowed for more options in the "group by" menu, but it didn't.
I would also advise that you use the "Give Feedback" option when you're in the next-gen project, detailing that you'd love to use swim lanes in the project; they're pretty good for responding directly to useful feedback!
Jack Brickey
swimlanes are not currently supported for NG projects.
Jack Brickey
FWIW you can watch the roadmap page for update but nothing about swimlanes. I will be a bit surprised if it is added.
