I'm looking for a better way to track larger projects, that span multiple sprints. I'm thinking that I'd like to see Sprints as swimlanes, and individual tasks grouped together by status (e.g. Not started, In progress, done).
Is this possible, or is there another solution that may meet my needs?
Julien, is correct, Gregory. This is a fairly common use case for Structure. If this is something you’d like to discuss or see feel free to reach out to us via structure@almworks.com.
In either case, best of luck to you.
-dave [ALM Works]
This could actually work as you can use JQL queries to build your swimlanes. However, you would need to update your queries everytime... Columns in the board would be your issue aggregation by status.
Maybe you could have a look at Structure for JIRA or Portfolio for JIRA if you need a higher level visibility?
