Hi all,
I have removed Epic issue type from my project and I want to use some other custom attribute or Story in my Roadmap board, how can I achieve that?
Currently when I load roadmap it give below error:
"Your project doesn't have epics configured
Lookup "Hierarchy Configuration" in your Advanced Roadmaps administration section. You need to assign whatever issue types you're using to the hierarchy. If you're not using epics, you need to assign another issue type at the epic level. You need Jira administrator permissions to do this, as it's in the manage apps section of system administration, and take note that changes to the global hierarchy are global and will be available to all projects.
Hi @Patty Land Even after adding Story under Advanced Roadmaps hierarchy configuration, I am getting the same error.
@Abhinav Srivastava what issue type is the parent of the story for your project? If you have no epic, you'd be adding an issue type at the epic level, which is the parent of your stories.
Hi @Patty Land I am using another custom issue type say 'X' which is parent of story and even after adding 'X' at epic level, roadmap board shows the same error.
