I have two questions related to Jira custom fields (have a basic understanding of Jira product):
- is it possible to add a Jira custom field to a standard Jira issue (as example a Jira story)? AS an alternative, I understand that I have to define a new (type of) Jira issue, in order to add my custom Jira fields.
- if adding custom Jira fields to story is OK, is it possible to make these custom fields visible only for specific projects?
Thank you,
Dragos
Hi @Dragos Liciu ,
Yes you can add custom fields to standard issues
also in context configuration you can define the project/issues you want to populate fields
Refer this article for more details and steps: https://support.atlassian.com/jira-cloud-administration/docs/create-a-custom-field/
Leo
