Using filter on a timeline
Corinne Guibert
Hello
I'm facing a strange behavior with the timeline view.
I have issues being part of epic and additional task. In my timeline, I want to see only the issues that are part of the epic.
I tried to filter using label, or using issuetype but each time the result is the same: in the timeline view, my issues are displayed outside their parent epic. When I remove the filters, my issues are back inside their parent.
Has anyone encountered this problem ? Any workaround ?
Result with the filter:
TimelineFiltered.pngResult without the filter  (which was my expectation);
Corey Waldner April 14, 2025
Yeah, I agree I have this same issue. When presenting our timeline, if I want to open it and show what's included in this EPIC, I can easily show (like a drill-down), not just make a list when filtering.
Laura Pellizzari
Hi
how's your filter like?
you should just use a filter that report the list of your Epics, and not the story/task/subtasks too
example: project = XY and issuetype = Epics
ciao
Laura
