Using pre configured Reopen Issue (3)
GilK
May 1, 2012
I've added a new transition for reoening an issue and jira created a new transition named: Reopen Issue (751)
Is there any way to use pre configured Reopen Issue (3) transition instead?
Janiv
GilK
October 14, 2012
Had to add my own transition.
JamieA
May 1, 2012
You can do it through hacking the workflow XML, but the easiest way is to use the graphical workflow designer. After drawing the transition you have the option to use a common transition, or clone an existing one.
Would be good if this was available in the old-style UI, as I don't like doing things graphically.
GilK
May 1, 2012
But Reopen Issue (3) does not appear in my Common Transitions list
