Using scriptrunner I need to know how to create multiple subtasks as a postfunction
rhianfarrell
I need to know how to create muliplte subtasks as a postfunction through a workflow transition.
I have to create upwards of 20+ subtasks per workflow status and need to know how they can be automatically added through transitions.
Does anyone have any script that will be of assistance.
Janet Whyde September 27, 2021
//This is a variation of Joshua Yamdogo's script above. I actually use two in the same //transition, since the value of the custom field determines additional subtasks
import org.apache.log4j.Level
log.setLevel(Level.DEBUG)
def cfManager = ComponentAccessor.customFieldManager
def stList = []
//Validate the value in custom field to determine if the additional subtasks need to be created
final cfTypeName = 'cf Field Name'
def cfType = cfManager.getCustomFieldObjects(issue).find {it.name == cfTypeName }
assert cfType : "Could not find this field on this issue $cfTypeName"
//Declare utility managers
def subTaskManager = ComponentAccessor.getSubTaskManager()
def issueFactory = ComponentAccessor.getIssueFactory()
//Capture the parent key value (should not be an issue inside a post function)
final parentIssueKey = issue.getKey()
def parentIssue = ComponentAccessor.issueManager.getIssueByCurrentKey(parentIssueKey)
assert parentIssue : "Could not find parent issue with key $parentIssueKey"
//Set the subtask item type to be created (5='Sub-task')
final issueTypeId = '5'
//Current user is the Reporter on the subtasks
def user = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
final reporterKey = user
//Assignee is the person assigned within the transition
final userKey = issue.getAssigneeId()
//Priority is inherited from parent issue
final priorityName = issue.getPriority()
//Create an array of subtask objects
stList = [
[summary:'Summary 1',description:"Description 1",originalEstimate:1800,estimate:1800],
[summary:'Summary 2',description:"Description 2",originalEstimate:1800,estimate:1800],
[summary:'Summary 3',description:"Description 3",originalEstimate:900,estimate:900]
stList.each { it ->
MutableIssue newSubTask = issueFactory.getIssue()
newSubTask.setAssigneeId(userKey)
newSubTask.setSummary(it.get('summary').toString())
newSubTask.setDescription(it.get('description').toString())
newSubTask.setOriginalEstimate(it.get('originalEstimate').toLong())
newSubTask.setEstimate(it.get('estimate').toLong())
newSubTask.setParentObject(parentIssue)
newSubTask.setProjectObject(parentIssue.getProjectObject())
newSubTask.setIssueTypeId(issueTypeId)
// Add any other fields you want for the newly created sub task
newSubTask.setPriority(parentIssue.priority)
newSubTask.setReporter(reporterKey)
Map<String,Object> newIssueParams = ["issue" : newSubTask] as Map<String,Object>
issueManager.createIssueObject(user, newIssueParams)
subTaskManager.createSubTaskIssueLink(parentIssue, newSubTask, user)
log.info "New item with summary ${newSubTask.summary} created"
Joshua Yamdogo @ Adaptavist
August 9, 2017
Hi Rhian,
Do you need each of these sub-tasks to have different information? Or will all of the sub-tasks contain all of the same information? Creating sub-tasks automatically on a workflow function is already a feature built-in to ScriptRunner.
  1. Go to the workflow step you want to create sub-tasks on
  2. Click add Post Function
  3. Click Script Post Function
  4. Select "Create a sub-task"
This built-in feature would work well if you need each sub-task to have different information, since you could customize each sub-task individually as a post-function. However, if you just need to create 20+ sub-tasks with the same information, you'd probably be better off with a post-function custom script like this:
def constantManager = ComponentAccessor.getConstantsManager()
def user = ComponentAccessor.getJiraAuthenticationContext().getUser()
Issue parentIssue = issue
if (parentIssue.getIssueTypeObject().getName() == 'Sub-task')
return
if (parentIssue.getIssueTypeObject().name != 'Feature')
return
def summariesList = ["Summary 1", "Summary 2", "Summary 3"]
summariesList.each {
newSubTask.setAssigneeId(parentIssue.assigneeId)
newSubTask.setSummary(it)
newSubTask.setIssueTypeId(constantManager.getAllIssueTypeObjects().find{
it.getName() == "Sub-task"
}.id)
//for JIRA v6.*
issueManager.createIssueObject(user.directoryUser, newIssueParams)
subTaskManager.createSubTaskIssueLink(parentIssue, newSubTask, user.directoryUser)
// for JIRA v7.*
log.info "Issue with summary ${newSubTask.summary} created"
rhianfarrell
Thanks for replying Joshua,
I need to have different subtasks at different stages of the transition however there will be many subtasks and I have been told that a custom script will be best for this.
I have tried the custom script you have provided however I am still getting a failed response:
unable to resolve class for:
Struggling to get a working script at the moment haha.
