Using scriptrunner's expression for fields with dashes in their name
Tiago Fernandes November 21, 2017
I'm using scriptrunner's issuefunction expression to compare two custom date fields in a jql. Example: issueFunction in expression("", "dateField1 < dateField2"). I'm having trouble when one of the custom fields have a dash in it, scriptrunner doesn't recognize the name of the field. When a field is called "date field 1", writing datefield1 on scriptrunner works. When a field is called "date - field 1", writing date-field1 on scriptrunner does not work.
Is there a particular way to escape dashes for custom field names in that situation?
Joshua Giffen May 11, 2021
issueFunction in expression("", "date - Field1 < date - Field2")
I was able to get a similar query working by using the customfield_##### reference instead of the customfield name.
issueFunction in expression("", "customfield_10600 < customfield_10601")
Alexey Matveev
November 21, 2017
Try to write it like this
issueFunction in expression("", "\"date - field 1\" < dateField2")
Tiago Fernandes November 22, 2017
That seems to result in an "java.lang.ClassCastException: null" error. I also tried it with system fields to make sure it wasn't an issue with the custom fields, the query
issueFunction in expression("", "\"updated\" < created")
results in that error, while if I remove the escaped quotes
issueFunction in expression("", "updated < created")
it works fine, returning zero results without any error.
Alexey Matveev
November 22, 2017
Yep, I guess it treats is as a string not as a field name
Like Efrain Luna likes this
Konrad Sass
December 31, 2018
Hi, I'd like to second the question. I have exactly the same issue. I want to compare two custom fields with dates
While:
issueFunction in dateCompare("", "Date of deployment INT > Date of deployment UAT")
works fine, similar field but different environment crashes:
issueFunction in dateCompare("", "Date of deployment INT > Date of deployment PRE-PROD")
with an error:
Field name: Date of deployment PRE not found or not a date or datetime.
Is there any way to overcome that?
david_parry February 13, 2019
Could it be because you have "-" in your field name? Maybe quote escape so it doesn't attempt to parse the hyphen as a "minus" operator?
e.g.
issueFunction in dateCompare("", "Date of deployment INT > \"Date of deployment PRE-PROD\"")
Then the parser should treat Date of deployment PRE-PROD as a a single entity rather than "Date of deployment PRE" <minus> "PROD"
