Using search_issues()
Daniel Ehrlich April 10, 2014
I am using jira-python 0.16 and am having fits trying to get search_issues() to work for me.
The following function is defined:
def findIssues(jiraInst, queryJQL):
    """ Return a list of issues that match the provided jql filter
        :param jiraInst - jira client object
        :param queryJQL - JQL filter string
    if debug:
        print >>sys.stderr, '*fi:JQL = \'%s\'' % queryJQL
    try:
        # Try to get all issues that match the filter
        results = jiraInst.search_issues(jql_str=queryJQL, maxResults=200)
    except (JIRAError, ValueError) as err:
        print >>sys.stderr, '* Search for \"%s\" returned an error \"%s\"\n' % \
            (queryJQL, err)
        return []
    return results
If called like
results = findIssues(jira, r'project = "A Project" AND status = "Pending User"')
The following error is returned:
Search for "project = "A Project" AND status = "Pending User"" returned an error "HTTP 400: "The value 'A Project' does not exist for the field 'project'"
However, if I use 'project = "A Project" AND status = "Pending User"' as a search filter in the web interface all is right with the world and issues are returned.
Searching for 'status = "Pending User"' returns issues across all projects as expected using either the function or the web interface.
Any suggestions or help would be appreciated.
Daniel Ehrlich May 1, 2014
Pilot error. No permissions for the user I was connebeting to JIRA as.
