Using the JIRA Configuration Tool to connect to an SQL instance
timrmoore July 12, 2011
I'm tring to connect the new installation to a blank DB, but the config tool doesn't seem to like me adding the SQL instance onto the hostname srting (i.e. LONDBSQLSYS2/IT where IT is the instance).
I note in the manual instructions that instances are supported. Is there a way to configue the instance through the tool or do I have to go through the manual route?
Richard Yale
July 12, 2011
Sorry I meant after the Database name. Add something like JIRA;instance=INST
Where JIRA is the database name
timrmoore July 13, 2011
Great, Thanks Richard
This should be added to the config db guide. Reference to an instance is there for the manual config instructions.
I've edited it manually now, but would be good to know if theres a way to do this using the tool
