Using the issue collector in React without jQuery
Daniel Cernogorsky
July 7, 2022
Is it possible to use the issue collector in React without jQuery?
I have read all of the issue collector questions here and have looked at examples in GitHub with no luck.
My next attempted will be to just use the API and create my own dialogs, but Id rather use whats available if possible.
Thomas Hoppe
September 5, 2024
Without jQuery I get `Uncaught ReferenceError: jQuery is not defined`. I assume it's required by the issue collector then.
Jörgen Dijk
March 1, 2023
Had a simular like issue with VueJS.
In VueJS you can add VanillaJS like this:
    mounted() {
      let recaptchaScript = document.createElement('script')
      recaptchaScript.setAttribute('src', '{{Atlassian.net_collector_url}}')
      document.head.appendChild(atlassianScript)
Source that helped:
https://stackoverflow.com/questions/56411378/how-to-add-vanilla-javascript-to-vue-js-project
Hope this will help someone out searching for this.
Oliver
July 29, 2022
Same here, our application works with VueJs and without jQuery. It were fine, when the collector is written in Vanilla JS.
