VBA code to get issue from JIRA using REST API
Franck Voufo January 24, 2022
Hi All,
I have a problem trying to get issues from JIRA to Excel (VBA) using a REST API.
Can you please help me? This is my code and the error I get:
Option Explicit
Public UserNameP As String
Public JiraService As MSXML2.XMLHTTP60
Sub JiraRestGetCall()
Call GetIssues("project = ""my new project""")
End Sub
' *** Returns the issues as per the JQL query ***
Public Function GetIssues(query As String) As String
Dim json As Object
Dim s As String
If JiraService Is Nothing Then Set JiraService = New MSXML2.XMLHTTP30
UserNameP = UserPassBase64
With JiraService
s = "https://atc.mycompanyname.net/jira" + "/rest/api/2/issues/?jql="+query
.Open "GET", s
.SetRequestHeader "Content-Type", "application/json"
.SetRequestHeader "Accept", "application/json"
.SetRequestHeader "Authorization", "Basic " & UserNameP
.Send
If .Status = "401" Then
GetIssues = ""
Else
GetIssues = JiraService.ResponseText
End If
End With
End Function
' *** Encodes the Jira Username and Password ***
Public Function UserPassBase64() As String
Dim objXML As MSXML2.DOMDocument30
Dim objNode As MSXML2.IXMLDOMElement
Dim arrData() As Byte
Dim URL As String
UserNameP = "JiraEmail:password"
arrData = StrConv(UserNameP, vbFromUnicode)
Set objXML = New MSXML2.DOMDocument60
Set objNode = objXML.createElement("b64")
objNode.DataType = "bin.base64"
objNode.nodeTypedValue = arrData
UserPassBase64 = objNode.Text
End Function
Response:
<!doctype html><html lang="en"><head><title>HTTP Status 400 – Bad Request</title><style type="text/css">body {font-family:Tahoma,Arial,sans-serif;} h1, h2, h3, b {color:white;background-color:#525D76;} h1 {font-size:22px;} h2 {font-size:16px;} h3 {font-size:14px;} p {font-size:12px;} a {color:black;} .line {height:1px;background-color:#525D76;border:none;}</style></head><body><h1>HTTP Status 400 – Bad Request</h1><hr class="line" /><p><b>Type</b> Exception Report</p><p><b>Message</b> Invalid character found in the request target [&#47;jira&#47;rest&#47;api&#47;2&#47;issues&#47;?jql=project%20=%20&quot;Ticketsteuerung%20Werkvertr0xe4ge%20Typzulassung&quot;%20AND%20Component%20!=%20Template%20AND%20(issuetype%20=%20Epic%20OR%20issuetype%20=%20Story)%20AND%20(resolved%20&gt;%20-8w%20OR%20status%20=%20&quot;In%20Review&quot;)%20ORDER%20BY%20resolutiondate%20ASC]. The valid characters are defined in RFC 7230 and RFC 3986</p><p><b>Description</b> The server cannot or will not process the request due to something t
hat is perceived to be a client error (e.g., malformed request syntax, invalid request message framing, or deceptive request routing).</p><p><b>Exception</b></p><pre>java.lang.IllegalArgumentException: Invalid character found in the request target [&#47;jira&#47;rest&#47;api&#47;2&#47;issues&#47;?jql=project%20=%20&quot;Ticketsteuerung%20Werkvertr0xe4ge%20Typzulassung&quot;%20AND%20Component%20!=%20Template%20AND%20(issuetype%20=%20Epic%20OR%20issuetype%20=%20Story)%20AND%20(resolved%20&gt;%20-8w%20OR%20status%20=%20&quot;In%20Review&quot;)%20ORDER%20BY%20resolutiondate%20ASC]. The valid characters are defined in RFC 7230 and RFC 3986
    org.apache.coyote.http11.Http11InputBuffer.parseRequestLine(Http11InputBuffer.java:504)
    org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:503)
    org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
    org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:831)
    org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1629)
    org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
    java.base&#47;java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
    java.base&#47;java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
    org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
    java.base&#47;java.lang.Thread.run(Thread.java:829)
</pre><p><b>Note</b> The full stack trace of the root cause is available in the server logs.</p><hr class="line" /><h3>Apache Tomcat/8.5.65</h3></body></html>
Sunny Ape
January 24, 2022
Hello @Franck Voufo
You haven't tagged your question to say if you're using Jira CLOUD or Jira SERVER, but in either case, the V2 REST API Get Issue endpoint cannot be used to search for Issues using JQL. You must use the Issue Search endpoint:
https://atc.mycompanyname.net/rest/api/2/search?jql=jql_query
Also, the VBA code that defines the URL has a number of mistakes in it:
  1. For Jira CLOUD, there is no '/Jira/' in a URL to an endpoint
  2. The question mark denoting the start of the JQL statement is not preceded by a forward slash
So, the VBA would be:
s = "https://atc.mycompanyname.net" + "/rest/api/2/search?jql=" + query
Try testing your REST API requests with a tool like Postman etc. first, before you attempt to replicate that in code.
Franck Voufo January 26, 2022
Hello @Sunny Ape ,
Thank you very much for your answer. I am indeed using Jira Server. I changed the url to s = "https://atc.mycompanyname.net/jira" + "/rest/api/2/search?jql=" + query as you mentioned. And I also found out that another reason I got the "HTTP Status 400 – Bad Request" was because I used a special language character in the jql_query like "ä". I then translated the special character in ISO-88592 with % in hexa, then it works: so instead of query = "***ä***" I wrote query = "***%C3%A4***" and now everything works without error. Thanks again
Josh January 24, 2022
It looks like it may be a related to this [CONFSERVER-57582] Later version of Tomcat hit into "Invalid character found in the request target" when subscribing to RSS feeds - Create and track feature requests for Atlassian products..  I'm wondering if this is related to the double quotes you have around your project.  Have you tried changing
"project = ""my new project""" to
"project = 'my new project'"
Hello @Josh  ,
thanks for your quick reply. I changed the double quotes as you suggested, but I still get the same error 😞
