Validator for checking Test cycle or test plan linked to issues
Mayur Gaikwad_Tech PMO
I'm looking out for option in Jira software wherein using validator at transition end I can check if zephyr scale test cycle or test plan is linked to issue then only user is allowed to transition to next stage.
Is this possible?
Andy Barbet
If an option exists, and I am doubtful that one does, it would be in traceability.  I am doubting that Zephyr Scale is that tightly integrated with Jira because you cannot use Jira Automation or Reporting and in most cases Issue Filtering for Zephyr Scale issues.
Maciej Dudziak _Forgappify_
June 21, 2024
Hi @Mayur Gaikwad_Tech PMO
I am not familiar with Zephyr. Is the issue connected by a Jira standard link? If yes, then it would be possible with Jira expression validators.
Cheers
@Maciej Dudziak _Forgappify_  No, infact there is seperate linking section for Zephyr issues
