I created some validators for required fields. They are working fine when doing the transition using a drop down in the Edit Issue screen and when a filed value is missing, an error message is returned. However when doing the same transition from Board view by draging and droping the issue on next status in the workflow, all validators are ignored.
I don't have any transiton screen configured, because I don't need it.
I am using a business worklflow template.
Please help.
It also doesn't highlight where I am allowed to move my task (to which status) as it does with software project.
My transition from To Do to In Progress is simple, with only 3 validators:
I have the same issue.
There is no 'required field' error message when the issue transitions in the board and it allows the transition.
If the field is empty when you transition within the issue, you do get the 'required field' error message.
It is not a system error message, it is a customized 'required field' error.
Hi William,
You should always create a new question for issues you are having so more people will see it.
That being said, I suggest you open a support ticket with Atlassian:
https://support.atlassian.com/contact/#/
Please post back here with the resolution so others can see the answer. Thanks!
Hi @Adam Siemionczyk - Is this still a problem for you? Trying to understand more to see if I can duplicate the problem.
@Adam Siemionczyk , welcome to the Atlassian Community!
Could you please specify the error message and add a screenshot of it?
