×Is there a way to see the dates from jira plans in the actual epics ? If you drive the epics based on the stories inside it are the fields being auto populated in the epics outside the plans ?
I essentially want to see the start and the end date directly in the epic based on what the plan is telling me. Is that possible ?
Hi @Bobby Moyini,
These dates are only visible on your Epics if they are actually filled out, not if they are left blank and rolled up from the start and end dates of your stories. Then they are just calculated fields displayed in your plan only.
Hope this helps!
