Viewing peer issues in Structure plugin (JIRA)
Rahul Aich [Nagra]
January 15, 2014
Hi
Consider this scenario, Issue A (is the parent) has two sub-structure issues Issue B and Issue C. (connected in a hierarchy using structure)
Now when I click on Issue A on view issue screen, i can see both Issue B and Issue C as the sub-structures in the Structure menu. (which is fine)
The problem is when i click on Issue B, although it shows in Issue A as its parent structure issue , it does not show me Issue C which is actually its peer in the structure relationship.
Is this a limitation of the tool or is there something configuration that i am missing.
I am using structure-2.4.3.jira5.jar on jira 5.0.2
Rahul
Robert Leitch [ALM Works]
January 15, 2014
Hi Rahul,
If you 'unpin' Issue B (by clicking the drawing pin icon at the left of the task bar in the Structure panel) this will give you the full view.
Described in more detail here - https://wiki.almworks.com/display/structure/Pinned+Issue+Mode
Best,
Robert
Rahul Aich [Nagra]
January 15, 2014
Thaks Robert, that helps.
