Want to prevent some groups from using System Dashboard
Dave_Harrington
I'd really like to set up external customers (each has a group assigned) so they cannot see the System Dashboard - or go into Manage Dashboards and select "Restore Defaults" which brings the System Dashboard back.
I don't mind (much, anyway) that users in these groups can create their own dashboards, but the System Dashboard is pretty unique for our internal groups, and gets ugly when used by and external user.
Can this be done?
Thanks!
Teck-En
February 28, 2013
I think you can do the following:
  1. Copy the system dashboard and share to system administrator or internal groups
  2. Go to Administration > System > User Interface > System Dashboard
  3. Revamp this system dashboard(default) to a dashboard which can be available to your external users
For more information on default dashboard, have a read on this documentation: https://confluence.atlassian.com/display/JIRA/Configuring+the+Default+Dashboard
Dave_Harrington
Thanks, tecken...
If I get this right - sounds like you're suggesting that I use the System Dashboard as the generic dashboard that ALL users (including external users) would see, and that internal users would then need to use the version that is shared specifically to them...
That will work - but it infers that there can't be a dashboard unique and specific for different groups. That's disappointing.
Teck-En
March 3, 2013
Hi ansky, i know it's disappointing in certain stage but i'm afraid that's the only way to do it at the moment as the default dashboard can't specify the group on it. However there has been an improvement ticket in our tracking system which address your requirements: https://jira.atlassian.com/browse/JRA-5866 You may watch the ticket to receive further updates on the ticket and most importantly vote the ticket to increase the popularity of the improvement so it will attract the r&d team attention. I hope it helps.
