Sometime over the last weekend (2/21 or 2/22) our system automatically received the new sidebar. In the process we lost the Issue Summary/Status Summary when selecting a Project > Overview > Issues. All we see are the Summary, Project details (lead, url, etc.), and Activity Stream. The screens at selectedItem=com.atlassian.jira.jira-projects-plugin:summary-page or com.atlassian.jira.jira-projects-plugin:issues-pane don't show the breakdown of tickets opened by status. How do we get this back?
Update details:
Target Version | Target Build Number | Time Performed |
6.4-OD-15-055 | 64014 | 22/Feb/15 9:40 PM |
I also miss the summary page (shortcut g+p). This site includes all essential project informations that i need. Where can i set this feature/site?
JIRA Cloud has been upgraded with a preview our new project navigation experience. The default setting is currently set to off. Your JIRA Administrator has the option to turn this toggle on for all users, or to select if they want the new navigation experience on or off by default.
To toggle between options:
If you don't see these options, your JIRA Administrator has set your default setting already, and you won't be able to change it.
When I set this to "Allow individual users" then each user can chose whether to use the new or old sidebar by going to their profile icon > enable/disable new product navigation. Interesting that an update 1. Turned off what appears to be the default (default), 2. Users in an entire organization need to manually edit their Profile setting to get back to a basic, useful function.
We are experiencing the same issue. How can we get the old page back when select Projects > project-name? We would like to be able to see the list of all the pre-canned filters (i.e. Resolved Recently, Added Recently, JIRAs assigned by Name, list of Versions, etc).
I selected 'Disable project navigation for all users' and then it worked. Issues Summaries and Groupings came back - FWIW.
Thank you!
Hi Carrie,
You can configure which navigation bar you'd like to use by visiting: Cog Icon > System > User Interface > Project Navigation.
Hope this helps you.
I think all that setting does is turn on or off the side navigation.. doesn't help with the missing summary features i am afraid..
What is the "Cog Icon" and where can i find this?
In the menu bar, top right, in between the "help" question mark and your profile icon. You need to be an admin for it to appear.
