Recently we have a task to migrate the test cases from one Jira Xray instance to another Jira Zephyr instance across VPCs. Upon searching I am not getting much except to export the Xray Test Cases and then import into Zephyr using Zephyr for Jira Importer Utility.
Please suggest if there is a way to write a custom microservice using java to post all test cases under one project from one Jira instance with Xray to another Jira instance with Zephyr.
I am from java development background. Please suggest in which direction it would be the best for me to venture.
Thanks a lot in advance!
Hello Debayan,
This is Sanjeev from Zephyr team. Yes, you can use the Importer utility.
To discuss this in detail and to look at the options, could you please drop me an email at sanjeev.pande@smartbear.com.
Looking forward to hearing from you.
Thank you.
Sanjeev Pande
