Hi All
I've got problem with triggering Gitlab pipeline from Automation setting in Jira. I've created a rule wich should send web request to trigger running pipeline in Gitlab. Using curl from command line it works fine, e.g:
curl -X POST -F token=some_token -F ref=main "https://gitlab.com/api/v4/projects/some_project_id/trigger/pipeline"
In Automation settings, i've got right target, using content-type as multipart/form-data, as request body i'm using "Custom" setting. "Custom data" field is set as:
(of course token and project are specific to Gitlab project). Trying to validate request, got bad request (400) with payload:
{ "error": "ref is missing, ref is empty, token is missing" }
I'll found solution: "Custom data" field should look like this (pretty simple):
ref=main&token=some_token
