Webhooks to show when an comment is made on an issue?
Cody Kukay
November 26, 2014
Using webhooks to integrate JIRA with Slack, however, I want a notification in slack when a comment is made on an issue. Is there anyway of doing this, as 'issue commented' is not a specific event in the webhook setup?
Yagnesh Bhat
May 18, 2016
We too need this, but basically when the issue is commented on a JIRA instance, it should post the same comment on an issue in another JIRA instance. Which issue on another JIRA instance? Thats decided by the custom field called "Other Instance ID" on the JIRA instance where the web hook is present.
Unfortunately its giving me the "
Client error - 401 when posting to web hook at 'https://the otherjiraistance.com/rest/api/2/issue/{issue id}/comment"
Farzad Panahi
same here, we need this feature. basically there should be an event like "on comment added".
