We are in the process of expanding JIRA to JIRA Studio to our new organization (we have merged with other 3 companies). We need your advice to find the best way to configure our new projects structure.
We have two options over the table and would like to have all pros and cons for its better eavaluation:
OPTION A
We have been told by Management the they mainly will need reporting on some main areas of the organization (products, incidences, suppliers, internal tools,...), but as we all know, they ask for all kind of reporting. At the first instance we have created a draft of architecture that consists of projects with these areas of the organization, and then components for products types, incidences types, and versions for new functionalies and change requests.
OPTION B
Well, on slide 39 in this presentation (http://www.slideshare.net/GoAtlassian/administrivia-golden-tips-for-making-jira-hum-1565231) it is said that its better to have many small projects better than fewer big projects, then have the projects under categories. I haven't found further criteria for this option that can help me to argument for this type of configuration.
We are new on creating this big instance of JIRA Studio and also, consider that we will be implementing Agile methodology with Greenhopper.
So..., if you have a big instance, and you could start from 0, how would you do it?
C
Actually, it's quite simple - you want to be Agile, so do many small projects. You'll rapidly find large projects become unmanageable and complex.
To simplify things though, use the same schemes to control the projects, and use roles in permissions. I try to use the same permission scheme over and over, and if you're careful with them, you can delegate all your worries about user maintenance to your project owners. I usually start from something like: "all users can read issues, only people in the role of user can create issues, and only developers can be assigned/work on/resolve". That lets you limit users when it comes to your "create" list.
If I had the chance to start from 0, I'd be very strict on the users "can my project have X" - establish a SHORT list of custom fields, issue types and workflows, and tell people to stick to the standard templates. Classic example at my current client - almost 30 different "date" custom fields, all of which could be covered with "start date" and "end date". Apparantly, it was critical that they're called different things because PMs needed them that way. (No, they didn't, we could have called them "Fred and Chuck dates" and they'd have worked fine)
If we have many small projects, it's going to be hard for users from the business areas to allocate correctly issues they find on the platform in general.
Is it possible to add the project categories at the new request wizard??
Just a thought here: the term "project" is a notion external to JIRA.
Charlie - consider having separate projects where your business users raise their stuff and don't let them raise directly in the development projects. That limits their need to know. You can then let the developers move stuff out of "triage" projects into their own development areas as appropriate, or they can create their own copies and link them to the business user issues.
There are some hard limitations for projects:
Ahd here are some tips:
Thanks Dimitar!
We will take your tips into consideration for sure.
Cheers
C
