What happens to add-ons settings after moving JIRA to another server?
Shirley Jhirad
I'm in a middle of a JIRA move from one server to the other. The DB moves as well to a different location. The old server has plugins such as Tempo timesheets and Salesforce connector.
So what i have done so far is:
1.Install JIRA on the new server
2.Restore the db
As far as the JIRA issues - they all load ok, Same goes for the Agile Boards.
Now my question is what will happen to the other addons i mentioned, Was there data and configurations preserved? Currently i do not see them under managed add-ons.
Do i need to install them again on the new server, if so, what will happen to the old settings i have?
What's the best approach to preserve all the old settings i Had?
Shirley
Michael Partyka
March 23, 2016
Hi Shirley,
before you restore db you should install all add-ons manually.
If you will not do this you will have many errors during import.
If you will have any questions let me know.
Deleted user March 23, 2016
It depends on what add-ons do you have. Some add-on configs are stored in the iTrack database or the JIRA installation directory. I constantly copy my production JIRA instance to a test JIRA instance and all I do is copy the DB schema and the JIRA home installation directory.
