What is a jql for getting issue order by accending order of value of custom field
Sachin Dhamale
List<Issue> getIssuesFromProject(Long projectId) throws SearchException {
		JqlQueryBuilder builder = JqlQueryBuilder.newBuilder();
		builder.where().project(projectId);
		builder.orderBy().addSortForFieldName("STRINGVALUE", SortOrder.ASC, true);
		Query query = builder.buildQuery();
		SearchResults results = ComponentManager.getInstance().getSearchProvider().search(query,ComponentAccessor.getJiraAuthenticationContext().getUser(), PagerFilter.getUnlimitedFilter());
		return results.getIssues();
In above codei want to get issue for given project ID and order by customfield value in asccending order.
"STRINGVALUE" is the column name of customfieldvalue table of jira where value of customfield store
but its not working can anyone tell me what is wrong in it or is any other way to get issue orderby of value of customfield
Bharadwaj Jannu
November 12, 2013
just try with
builder.orderBy().add("your customfield name",SortOrder.ASC);
Sachin Dhamale
Hi Bharadwaj
i try this but its not working
		final CustomField customField1 = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("WBS");
		//builder.orderBy().issueKey(SortOrder.ASC);
		builder.orderBy().add("WBS" , SortOrder.ASC ,true);
		//builder.orderBy().addSortForFieldName("STRINGVALUE", SortOrder.ASC );
		//builder.orderBy()("STRINGVALUE", SortOrder.ASC,true);
in this WBS is my customfield name
WBS field Contain
1
2
3
Bharadwaj Jannu
November 12, 2013
ok Sachin, is it throwing any error?
Bharadwaj Jannu
November 12, 2013
List&lt;Issue&gt; getIssuesFromProject(Long projectId) throws SearchException {
	    builder.orderBy().add("FIN" , SortOrder.ASC ,true);
	    SearchResults results = searchService.search(ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser(),query, PagerFilter.getUnlimitedFilter());
in my constructor I wrote like this to get searchService
import com.atlassian.jira.bc.issue.search.SearchService;
public EditLink(SearchService searchService){
		this.searchService=searchService;
this worked for me and FIN is of select list type.
Bharadwaj Jannu
November 12, 2013
MJ
November 11, 2013
In JQL you would not order by the name of the custom field, rather by the custom fieldID. This would look something like "ORDER BY cf[10100] ASC" where the value of cf[] determines which custom field is being used.
Sachin Dhamale
but Mick how we use this custom field ID in this syntax.
Means where we mention customfield ID in orderBy() method
Can you modify above code with corrected code according to requirement
