  • Community
  • Products
  • Jira
  • Questions
  • What is the best SVN tool out there for Jira? Specifically for using revision/commit # for searches and reporting?
Rob Horan
May 23, 2016
We are currently using Subversion ALM but there aren't a whole lot of JQL operators, and the syntax has a steep learning curve.  Any help is appreciated.
Chris Dunne
May 23, 2016
Have you looked at Atlassian's Fisheye?
Pablo Beltran
May 23, 2016
Sure he knows that FishEye exists. The question would be: why is FishEye better than Subversion ALM for reporting?
Rob Horan
May 24, 2016
We did look into FishEye, but had troubles getting it up and running.  It's also far more costly than what we're looking for.
Rob Horan
May 24, 2016
Pablo - we've been very happy with Subversion ALM but there are a few things that would knock it out of the park for us.  I sent some emails but never heard back.  I'm sure these will sound like nit picks, but they would be of great value to us.
The ability to sort the SVN ALM tab in reverse order, with newest events appearing on top would be HUGE for us. All of our other tabs are sorted this way.    We like seeing the latest changes immediately.
We could use some more JQL.  Several of us need the ability to search for issues with no commits.  I see no easy way to do that.
The other thing we want is the ability to actually write to a JIRA field, rather than always relying on reading from SVN.  For example, latest revision.
