×You can use TFS4JIRA plugins.
https://marketplace.atlassian.com/plugins/com.spartez.jira.plugins.bork.tfs4jira/cloud/overview
Basically, this tool can perform a sync between your TFS and JIRA issues. Thus, all issues from TFS will be imported to JIRA. But, do be informed that there are limitation such as history and certain type of fields cant be migrated, and attachment size is limited.
I'll share a blog regarding this later on once my project is completed
Hi Azfar
Actually i'm interested in migrate between TFS and JIRA so if i saved a bugs in TFS through MTM how could the bugs appear in JIRA or how could i query bugs from TFS through jira , or maybe i try to another soluation by export all bugs from tfs and import it to jira?
thanks in advance
Hey Taha,
"if i saved a bugs in TFS through MTM" - I'm not really sure the MTM you are referring to here.
Basically, using the TFS4JIRA tool, you can create a migration profile for each work item type you would like to migrate to JIRA. So for example, if you want to migrate Bug WIT from TFS to JIRA, this is how the flow is:
So basically, for example, if your project have 4 WIT type (such as bugs, improvement etc), you have to create 4 migration profile to migrate each of the work item type.
Hope this helps
Hi Azfer,
I really appreciate your help . to make it clear i can create bug on MTM and it saved and appeared on TFS i can export WIT bug from TFS easilly as csv file .The point now is to export bugs from TFS through jira orit automatic created at jira .
* How can i create migrate profile . and run it ?
i just want to import WIT bugs only on jira
If i install TFS4JIRA tool then i could see all bug that created on TFS through Jira
Hey Taha,
No problem. So,follow this exact step:
If you need further detailed steps/help on this, I would recommend you to contact the Spartez Support - support@spartez.com
Cheers
Dear Azfar,
Thanks for all the info. This is helpful.
About your comment: "But, do be informed that there are limitation such as history and certain type of fields cant be migrated, and attachment size is limited.
I'll share a blog regarding this later on once my project is completed"
Would you have some update? I have been asked about migration from TFS to JIRA and would need to know how best to migrate attachments and history.
Thx!
HI Sreeram,
Please check answers below for the same question. I personally haven't any experience with it:
https://answers.atlassian.com/questions/287434
https://answers.atlassian.com/questions/113598
Hope this helps.
Cheers
