What is the difference between Task and Sub Task? Understand sub task is next to stories only.
Arun August 21, 2018
What is the difference between Task and Sub Task? Understand sub task is next hirerachial level to story only. Please clarify
Mark Markov
August 21, 2018
Hello @Arun
Yes. Difference between task and subtask just on logic level in hierarchy. Technically subtask is the same Issue object as Task.
